1 - 11 of 11 Posts
Sorry if this is in the wrong section!!
Can anyone tell me if there is a way to keep the wipers up when cleaning the windscreen, as I tried on Saturday and they catch on the top of the bonnet and I couldn't lift them, hope this isn't a stupid question.
Not a stupid question at all. There is a trick to doing this :D
If your car is turned off: Get in with the keys ,push the start button twice so the ignition is on but the engine is not started.
Now push the start button again so the ignition is turned off -
Pull the lever towards you (the one that operates the wipers) as if you were going to use the washers. The wipers should move to almost vertical and then stop. You should not be able to lift them up :D
Thank you Meaga-byte
I'll give that a go.
DonnaB
Not a problem, I read it in a manual and went out to try it on my tekna before i posted the instructions :D
well its all thanks to this forum.
With the help of you guys i have learnt many ins and outs of the juke that i didnt know before (and randomly pushing buttons while reading the manual lol)
So in the true Juke spirit its only fitting to pass on ones information to the next person :D
haha indeed :D
Im having brandy snifters with my dad.
Something he was doing in the maldeaves.
Take a sip of brandy, wait for the burn and then take a sip of hot coffee.
Rather odd combernation but i can see it becoming addictive.
If you want to feel a proper burn from a drink, try a Woods Rum, I was brought up on this stuff, when I was in the Andrew
I might have to give it a try :D
If you want something that takes the back of your head off
try stroh Rum. has to be imported via sea as its to volatile
to be brought in by plane :DEdited by: meaga-byte
1 - 11 of 11 Posts
