1 - 6 of 6 Posts
Can you please advise just found the front and rear floor wet in my wife's 2018 1.6 juke any ideas ??yes the windows were shut .
Wet floor and 2 litres of water in the spare wheel well.
Found the carpet and rear seat wet, dried it out, been trouble shooting (poured a watering can of water over the roof) and found water coming in at the rear passenger side corner. There appears to be a space between the outer body and the inner at the rear corners. water is collecting in the space between the body work and leaking into the boot space over some sealant between the body panels. Checked the other corner and found water between the panels though it did not leak into the boot space.
Not sure if water is supposed to run into the void but then drain away.
Wondered if anyone else seen similar
I have just discovered this happening in my 2018 June to so sending it back to garage it came from. That should not be happening at all.
1 - 6 of 6 Posts
