1 - 12 of 12 Posts
Hey guys new to the forum
Was wondering if anyone could help. I have a n tech 1.6 diesel 2013 plate.
I've had these warning lights come.on at the same time. Can anyone she'd any light?
Sent from my SM-G900F using Tapatalk
Hi I have the same car of the same year 2013, one day so the same light has lit but when the car cools and I turn it on again the light disappears. It happens when I drive in the city for a long time. In the manual of the vehicle there is no indication of what could be, thank the help of the specialists before taking the vehicle to Nissan.
They are warnings! Best thing is to go to your dealer asap!
In the user guide is a page, near the front, of what all the symbols mean.
Hey guys it turns out it was the dpf and something to nd with the pressure valve.
Thanks, following your advice, I'll take the car to Nissan, maybe they can check for any errors.
I was desperate because I could not find the possible causes, thanks to you I was clear, even having to go to Nissan. Thank very much
Thanks everson38 and acrorat!
Discussion Starter · #10 ·
In a away but it wasn't long term but suited what I was planning g to do:
Sorry for delay I never saw the message. In the end I used some wurth DPF cleaner and applied it to the DPF filter and followed the instructions. It made it better but cannot say for sure. As it was flagging up some fault codes originally but then I did the cleaner and then cleared the codes and then I traded the car in for a new model. As the place I was looking at would only give me half of what car is worth with fault codes on it. So had to get them cleared first
I bought £5359 11 plate 6 mths ago , these lights kept flashing up the wee skidy car one is supposed to come up when it slips on something which it does quite often , the engine management light well I replaced injectors twice because of these lights only to find it was a faulty wiring problem too the injectors. It makes the injectors miss causing the back end to skid . I had to sell car at market £3000 :(
1 - 12 of 12 Posts
