Hi,
I've got a 2012 Nissan Juke 1.5dci, at approx 1000rpm there is a loud vibration/rumble noise coming from the engine. It only happens at 1000rpm, doesn't matter whether in neutral, in gear or when the clutch is being depressed.
If the revs drop or increase then the noise stops.
Any idea what this could be? I've read that it could be a couple of different pipes (air filter and air con) rubbing the body work, but couldn't see this. Any images of where they actually are?
Thanks in advance
Dan :)
Mine did this and it seemed to be the dpf filter wanted a regeneration...it was particularly bad when i used aircon in hot weather..it would seem to vibrate a lot..is your different in hot and cooler weather?? Does the power seem to be lacking?? I did a forced regeneration on my dci and it seems to have worked a treat...I'm not saying it's same as what I had..but it's very similar...good luck
