This was a question posed on a different topic, so decided to bring it across.
Hope you don't mind.
Setting the speed locking
1) Turn the ignition key to the on position ie so the warning lights come on
2) Push the central locking button (by the window switches on the drivers side) until the hazard lights flash twice
two flashesis set one is deactivated
This will lock the doors above 6 mph.
Doors can still be opened from the inside, and automatically unlock in the event of a collision.
There is another setting which unlocks the doors when you turn the engine off and take the key out.
This procedure is identical but operate the switch as if to unlock the doors.
Again two flashes activated one deactivated.
