I've just remembered at the end of my test drive I tried to be clever and reverse into a very large space only using the rear view camera, I only nearly took a Micra that was parked some distance away with me!!!
I was really hoping that being able to see something would be as good as a beeping sensor - better in some cases such as raised curbs and posts that might not be picked up.Siemarque said:I had a reversing sensor dealer-fitted in addition to the camera.
The camera just shows what's there - it does alert you the way the beeper does.
Eyes & ears
Stormrider said:I did an amazing parallel park the other week in a space only just bigger than the car (probably 50cm clearance on one side and 20cm on the other), wheels up against the kerb and everything. No reversing camera required!
How does your rear bumper look now? Any pics?Siemarque said:I had a reversing sensor dealer-fitted in addition to the camera.
Eyes & ears
I have two reversing cameras fitted actually... one in my left eye socket, and one in my right eye socket! You can even transfer them from car to carLady juke said:Stormrider said:I did an amazing parallel park the other week in a space only just bigger than the car (probably 50cm clearance on one side and 20cm on the other), wheels up against the kerb and everything. No reversing camera required!
Do you have one![]()
Brilliant!Stormrider said:I have two reversing cameras fitted actually... one in my left eye socket, and one in my right eye socket! You can even transfer them from car to car![]()
