1 - 9 of 9 Posts
Hi all
My near side read door handle is sticking, it does not go back
by itself. I have to manually push it back so door will close.
( Juke Tekna )
Any tips on what to do. is it a case of taking the door panel off.
Don't fancy that mmmmm.
Regards Keith
I foolishly sprayed mine with WD40. It fixed the issue, but it affected the finish off the handle as I didn't clean it properly afterward.
Hi all
( Juke Tekna )
Regards Keith
I have the same problem recurring. I spray WD40 IN TOWARD THE MECHANISM SEEMS TO WORK FOR A WHILE.
Hi all
( Juke Tekna )
Regards Keith
Hi I've got the same problem ! Did you find a solution ?
The inside of the door has a small plastic panel that will just pop off with a screwdriver and spray some lubricant on the mechanism. 2 min job
Any chance you could take a picture of where you put the screwdriver to pop it off pls? Been looking and can’t see where!!!
1 - 9 of 9 Posts
