1 - 4 of 4 Posts
Hello everyone Hope you are all well,
We have an issue with our diesel Juke where it will suddenly start bellowing out smoke then it will stop and be fine?
The smoke is Blue so it is oil. Has anyone else had this problem before?
Can be going along at 60 mph perfectly fine then all of a sudden smoke bellows from it and then clears up? It can last 20 seconds to 2 minutes. Since it has started doing this we have stopped using it!
Thank you so much any help is appreciated.
Discussion Starter #2
The garage has refurbished the turbo and also re furbished the EGR valve (I think it is called)
Still doing it.
Any help would be great :(
Discussion Starter #4
Would that not mean it would do it all the time? As it is constantly blowing by the pistons?
Was doing some research and someone else had this problem and they found it to be the DPF filter. What would your thoughts be on that?
Thanks for the reply!
1 - 4 of 4 Posts
