1 - 1 of 1 Posts
Post Top Light 100W 13,000 Lumens IP67 5000K 130lm/w 100-277VAC,It has been calculated that if Japan were to replace all its lighting with leds, it would reduce the number of large power plants by two, which would be good for the environment.Fast response time: leds typically respond in tens of milliseconds, making them a high-speed device that no other light source can match.
Post Top Light 100W 13,000 Lumens IP67 5000K 130lm/w 100-277VAC,Low power consumption,LED is a kind of low-voltage working device, so in the same brightness, the power consumption is the minimum, can greatly reduce the energy consumption,On the contrary, with the development of technology and materials in the future, it will have higher luminous efficiency. Post Top Light 100W 13,000 Lumens IP67 5000K 130lm/w 100-277VAC,It has been calculated that if Japan were to replace all its lighting with leds, it would reduce the number of large power plants by two, which would be good for the environment.Fast response time: leds typically respond in tens of milliseconds, making them a high-speed device that no other light source can match.
2745
1 - 1 of 1 Posts
