yes is working, this post is from my mobile phonedeks36 said:found this response for Dan about mobiles Just been on their support forum, its apparently to do with the Rich
Text Editor. If you edit profile and turn off the WYSIWYG Post Editor
you should find it works ok.
this means nothing to me I found it it the club section under forum updates
It works for the iPad - I had the same problem with a few forums but it's resolved when you change that setting.Hudson said:I have changed mine so I will give my iPad a try later, thank you!
