1 - 1 of 1 Posts
Premium Member
Redline Water Wetter is compatible with new or used antifreeze (including DEX-COOLTM and long-life versions) to improve the heat transfer of ethylene and propylene glycol systems.
Benefits Include
? Reduces or eliminates bubbles or vapor barrier that form on hot metal surfaces to reduce coolant temperatures by up to 20°
? Superior heat transfer properties compared to glycol-based antifreeze
? Improves heat transfer and reduces cylinder head temperature
? Designed for use with all modern aluminum, cast iron, copper, brass and bronze cooling systems
? Price: £15.18
1 - 1 of 1 Posts
