My wife’s 13reg 1.5 Tekna had the pipe from the throttle housing to intercooler break, I tried to run it to the garage but it cut out , it would start but no power when the throttle was pressed, then cut out , got taken the the garage where they replaced the pipe ,( independent garage) the car starts but cuts out after about 10 seconds, ,fault codes are fuel rail pressure sensor , exhaust pressure sensor B, PO47B, csf relative pressure sensor, P047B,engine signal1,C1130,
It’s going into a diesel specialist on Thursday,
Anyone have any idea what’s going on
It's probably clogged up with soot if it's the pipe I'm thinking of. Take the exhaust cat off, wash it out and re-fit it. The diesel specialist may be able to flush the system with a carbon cleaning machine but it's not cheap.
Sent from my SM-G920F using Tapatalk
