1 - 5 of 5 Posts
Up to today I've had no issues with my iPhone 4. Calls were working ok via Bluetooth, my USB connection has had no problems and Bluetooth audio was working fine when I didn't want to bother with my USB lead.
However today the Bluetooth audio is not working and all I'm getting is a message saying "no remote command option" or something similar to this, can't remember exactly.
The only way I can get Bluetooth audio to work again is to clear my iPhone connection and pair with the car again. This is a pain and I cannot understand why Bluetooth audio has suddenly stopped working when I start the car.
Is your iPhone software the latest? Maybe and update/restore will fix the issue.. Personally I always use the USB connection as you have control of the phone from the car audio and it charges while in use! But each to their own !!
I found that if I started to try and use the iPhone via the BT connection before it had downloaded properly then I would get this message too. Just wait a little longer before try to use the BT controls. Hope this helps.
1 - 5 of 5 Posts
