my above comment is based on what the computer said I know its not totaly accuratebeltanedeath said:@ deks<div id="myWatcherDiv" style="display: none;">
are you using this
http://www.evilution.co.uk/pages/mpg.htm
if not, could you use it the post what mpg that says you are doing?
Sean
Sean I know how to calculate my mpg correctly and dont need an electronic program to tell me what I know. and as has been said the calculator is doing exactly the same as I do manuallybeltanedeath said:again the brim to brim can be a bit hit and miss....try the link......might make you smile when you find out your getting better mpg than you thought?!?!<div id="myWatcherDiv" style="display: none;">
Sean
I hope you mean 36 mpg and not 3600 mpg, if not keep the bloody MicraOuch! said:Best way to calculate is, to make it up.....My 1.4 Micra does 3600 mpg.
See it's simple when you know how!
Ouch!
