***Need examples of similar cases to prove to Nissan that this is a common fault!***
I bought a 1.2 Petrol in 2015 which has been in the garage more times than I can remember. There have been issues with the oil consumption, it has needed the timing chain replaced, had software updates twice and now needs a full engine replacement at 20,000. Nissan want me to contribute towards the cost because it is out of warranty which I think is bang out of order because from the research I have already done, it is clear it is a common fault. I have paperwork of the exact same car two weeks younger than mine which had to have an engine replacement just last month. I have already been through these forums and found several similar cases but could you please share if you have had similar issues with a Petrol Juke!
