1 - 8 of 8 Posts
I've not read the manual recently, so apologies if it is in there, but does anyone know if the Juke headlights can be adjusted for driving in the right in Europe? Presumably the switch that raises/lowers the beam won't help as it's the left/right throw that is the issue...?
If not, are stick on beam deflectors the only solution?
the beam is thrown by the reflectors inside the lamp the only way to alter this is by using the stick on deflectors, these have to be placed in the correct position to work properly aswell
A tip. If, like my Dad, you are a bit of a skinflint when spending money.
My old Dad has stick-on deflectors on his car, but he saved the backing that they came on and re-uses them each time he goes to Europe.....So far they've lasted for loads of trips.
Ouch!
Thanks both.
Anyone know if the connect sat nav does European street level guidance too? Specifically France, Belgium, Holland and Germany...
1 - 8 of 8 Posts
