Hi all,
I have a 2014 Juke, since new i’ve had issues with the front washer jets not working correctly just a dribble comes out the front jets.
they replaced the jets under warranty last time worked ok until now.
I’ve tested the jets themselves myself, when i put my finger over the pipe of one of the jets the other seems to work as it should with the required pressure pushing water out.
if i try & use them both one works pathetically & the other not at all.
i’ve cleaned it all out, bought new jets still the same.
Do we think it is the pumps not got enough gumf to push the water around & spray out correctly?
rear washer jet works fine ?
sorry it’s long winded ?
Hi,
It sounds like it’s the pump or a small blockage somewhere between the tank and where it splits for each side
Sent from my iPhone using Tapatalk
