1 - 14 of 14 Posts
I've just discovered my front fog lights aren't working, is there something I can do to fix it myself or should I take it to the dealer?
What do you mean by not working?
I havent played around with the Fog Lights yet but
from what i have seen there are two settings. One turns Either front OR back fog lights on and the second turnes Both front AND back on. In which order this happens im not sure. If you cant get them to work at all then i would sugest a trip to the dealers :D
Thanks Meaga-byte
The fronts ones don't light up the back one does, was just trying to avoid a trip to the dealer so thought I would ask on here, I did have front parking sensors fitted so maybe something to do with that?????
Thanks again.
DonnaB
X
Well to sit Parking sensors they would have removed the Bumper and it seems that they forgot to reconnect the fogs, or it might be something as simple as putting a fuse back in. Maybe if you have the time have a quick look under the bumber and see if the Fog cables are attached.
Hi DonnaB & mega-byte
With Headlights on the first turn of the stalk puts the rear fog lights on, a second twist leaves the rear fogs on & switches the front fogs on.
Regards
Wizard
Regards
Wizard
Are you sure?
my Juke is out at present but my other car works the other way round first turn is front second click is front and rear. This is why you see chavs
driving around with the front fogs on in all conditions
Edited by: jukezilla
Hi jukezilla
Sorry guys my mistake I stand corrected, first twist front fogs, second twist both front & rear. I've just checked, I'm sure it was the other way around on my previous car.
Regards
Wizard
Thanks Wizard
Have tried all combinations, still not working, going to have a look under the bumper to see if anything has been left disconnect after the sensors were fitted.
Then take it back to the dealer Donna. Don't try to mess with them yourself, as it may invalidate your waranty. It is up to the dealership to sort them out for you.
Make sure you have headlights on as well, the fogs don't come on unless the headlights are on I think.
Yay found the problem, they weren't connected, so have now reconnected and they work
, there was a sensor by the side of the left one, anyone know what that's for? I'm guessing it's for the outside temperature?????
Thanks for all your help!!
DonnaB
Glad they are all working now DonnaB
So they forgot to reconnect them lol, and yes that sensor is for the temp gage :D
Discussion Starter · #14 ·
Thanks again for your help meaga_byte, I might have a few more questions for you soon!!!!!
DonnaB
XX
1 - 14 of 14 Posts
