1 - 20 of 31 Posts
Foot well lights.
Use LED strips, stick either on entry guards or on seat base.
Run +ve wire from boot light brown wire and –ve from door switch.
Remove boot light (pull out) and run wire down into wheel well along and under edge of seat. (do not connect to light until everything else is connected)
Remove door switch pozi screw, door seal trim and entry guard (pull up) and scotch lock wire to switch and run wire down door channel.
Test before hand and make sure you have +ve connection for LED marked. Connect your LED to the wires you have run (+ve to boot light –ve to door switch) (I crimped mine), decide where you want the lights, either on plastic of entry guard or under edge of seat.
Connect boot lamp wire and you should have light.
Stick LED’s where wanted.
Tuck surplus wire under entry guard, tape out of way.
Do the same for other side as door switch only works for one side.
Replace trim.
Extra light in boot.
While running foot well lights you can easily add an extra light in boot, just run extra wires from boot lamp connecting to _ve blue wire and +ve brown wire to extra lamp. I used truck marker light, self adhesive. Ran wire through grill and into wheel well.
Edited by: deks36
Get all your bits together and check the LED connections, that should be easy because most come with black and red wire. Should take under the hour. I used crimp connectors and scotch locks. Screw connector block is just as good with scotch locks.
Plug them straight in your 12v supply via an inverter
Nice pikey style
Oooh I have plenty of that in stock, hmmmm gets me thinking what else I can use it for (in the juke, before anyone thinks).
You could add Velcro to stop your handbag sliding about or a velcro spice rack??
Kats said:
I was thinking of these but not sure how to wire them in yet.
Same way kats, standard lamps, standard wiring method .T
1 - 20 of 31 Posts
