Hi after our recent cold spell my external temp is displaying a constant -30c and the climate control inside is playing up are both connected ??
also does anyone know the location of the sensor ?
Any help would be appreciated as I can not take the temp above 16 otherwise i start to bake !!
thanks
sorry forgot mention it is a 2012 Juke that i have
thanks
Ours is a 68 plate. The sensor is located just behind the grille on the near side about 300mm in on a flexible plastic side strip.
The gauge started giving some readings that were obviously a little wrong, then just showed 60C constantly. Eventually found the sensor (after thinking it was the airbag sensor then front camera!) and took it off, now shows -30C with no sensor connected. Awaiting delivery of new sensor…
