1 - 13 of 13 Posts
Can't seem to find this, anyone know the power/torque curve for 1.5 DCI?
When does the max torque die off? On my yaris it was 2000-3000rpm for torque and something like 4000 for the HP
Hi, the spec states `Torque 240Nm from 1750 RPM up. Max power 81 KW @ 4000 RPM`
Hope this helps..
Ozza
Kats said:
I want one then, just uploaded the speed camera data tothe connect system, me can go faster now.......
yes need to do that if I can find the info that was sent to me other than that hoping someone one brings a copy on the 29th and does it for me
I would imagine a remap on the DIG would be awesome
Edited by: deks36
re maps work by fine turning the engine management system. ok so for instance the juke is release world wide, the engine has to be able to cope from good quality petrol/diesel through to horrible stuff (i'm not talking about the difference between jet and shell) so a remap will tell the cars brain that it doesn't need to worry about the rubbish stuff anymore and concentrate on the good stuff and to adjust the fuel mix appropriately. So a remap should give you more power and better mpg if your lucky! There's more to it but that's the simple version
Sean
Edited by: beltanedeath
1 - 13 of 13 Posts
