1 - 5 of 5 Posts
is there a way that you canstart the car and alwayshave the climate control on? i have tried looking at the setting but cant figure it out. It always starts with it off, then within a few minutes i need to switch it on as the windscreen steams up. Any ideas?
It's always on for me... the windscreen mode seems to automatically select itself when it is required as well - probably when the temperature is below a certain value.
as Storm says I think if you select windscreen it automatically operates the a/c from start up.
It does on mine anyway.
may i need to turn the temperature up/down to reflect the temperature outside? then it may stay on
when set to windscreen the a/c comes on to demist faster(more economic)
otherwise it stays off as that is how they get to the co2 emissions and fuel economy figues if it was always on that would be termed the 'norm' so the ratings would be based on this.
i had a customer ask the same question on a new E class Coupe and that was the answer i got from merc technical so i would assume its the same rules for all.
1 - 5 of 5 Posts
