1 - 5 of 5 Posts
Hi,
I have just bought a 2014 Juke Acenta Premium
The automatic mirrors are not folding. The switch is illuminated and I’m hoping this is the on position. I have checked the fuse and that seems ok.
Any help would be appreciated
Hi,
Did you find out what the problem was or how to fix this as I’m having same problem with mine same model and year thanks
Hi Teeside, have you tried the key fob, and/or the
button on the door handle, I had to press the door
handle harder each time- so now I just use my fob,
I suspect it's an electro-mechanical prob. with the
handle switch possibly. Regards.
What button on the door handle? Also what do you mean about use the key fob, as I use key fob all the time to unlock and lock it I’ve even tried holding the lock button for a few seconds, double pressing it and they are still not working ?! Thanks for replying though
Apologies, I wasn't very clear, in my case I had the
same prob, mirrors wouldn't fold when locking the
doors, as you said the switch was illuminated-( but
mine doesn't) it just says "auto/man" I kept knocking
it to manual(with my knee). which in effect turns them off, until I sussed out (in my case) what was
happening. Anyway not withstanding that, there's
a small rubber-like button built into the door handle
when pressed ,on exit folds my mirrors, & locks-up
the vehicle. provided the switch inside is on auto
otherwise nothing happens in my case.!
Again sorry for the previous (fuzzy logic).
Merry 🎅 Xmas!
1 - 5 of 5 Posts
