1 - 6 of 6 Posts
Does anybody have a "two stage" accelerator pedal? Difficult to describe - but if you "floor" the pedal, you think it's down all the way. Then if you really press it down hard again, it goes further?
Is my pedal getting stuck on the carpet, and the last hard effort is just to compress the carpet? Or is this last bit of stiff travel part of the kick down mechanism for auto boxes? (Mine is manual, but maybe pedal mechanism is common?)
Or is the last part of my pedal travel frozen??? (See earlier rant about screenwash - I hate the cold!)
Hi there,
This is the over-ride mechanism for the speed limiter.. for safety, you need to be able to over-ride the set speed quicklyif required so this is achieved by pressing the pedal completely to the floor..
So don't worry, there isn't a fault with your car..
I have had it in eco for the past couple of weeks as it really helps handling in the snow, stops too much power getting to the wheels etc. It's not all that bad when you get used to it for a while, but nice to have it back in sport again now everything has melted around here :p
Can't say it exactly gives much of a power boost pushing the pedal past the resistance point... it's just there to override the speed limiter really.
Edited by: Stormrider
1 - 6 of 6 Posts
