So I've got a 2011 juke turbo. Starter went out. So I swapped it out. Now the car won't turn on. I get no dash lights or hvac. Radio works, nav works, all lights work. The little light for the brake switch for starting comes on. It won't go off when I press the pedal. (I replaced that just now) but basically the vehicle won't go into"on" position. Its like it's only in acc position. This reading u1001 and u1000 codes in the engine and trans ecu. No bad fuses. I can read all the engine and trans sensors in my scanner. But no dash and no start. I'm pulling my hair out
