I noticed what could only be a hissing noise coming from behind the instrument panel (although i suspect its from the engine bay) it was intermittent at first only under load not at idle it then became constant and a little louder now it sounds metallic its only when under load but in addition to that acceleration is lumpy pressing the accelerator hard the car resists accelerating you have to back off and the turbo boost is restricted - i have had a quick look under the bonnet before it got dark tonight cant see anything has anyone else experienced this - im going to check the ecu in the morning even though the engine light isn't on i've heard there could be a stored code? TIA
