Never thought I'd have to come in to this area this early.
May not be a biggie, this.
This evening we got out of the car & I tried to lock the car with my conventional remote key. No lights nothing. So I opend & closed all doors again. No luck.
So I switched on the key (ACC) & then saw the door open indicator pointing to back left door. I got out & opended closed a few times didnt work. Pushed the rubber bush thingy (where it presses against the door) couple of times, no luck. So I drove around the block two rounds & then tried & it worked this time.
I have no idea why this happend. Do you?
Is it the weather causing these small issues?
Has this happend to you guys?
I hope it will not repeat!
Juke me
Juke me
